zeekh
HAs anyone done this DIY? Did you use the Lowes/Home depot type machine? Is the cellulose the same stuff they sell at Lowes or HD?
Thanks
Thanks
Thanks for the information, I will definitely keep this in mind when I insulate my garage.I have done it three times. The home depot/lowes machines are garbage and will not do it. These are about the size of a 55 gallon drum and same shape. They have no control of the air nor is it strong enough.
Our menards however has a large krenol machine that you can control both the speed of the material being fed in and the flow of the air. It works well to dense pack.
You do it all the way up. Poke a hole 6' up and shove the hose down to the bottom. As it packs you slowly pull the hose back. I wasn't doing 10' walls(8') but I could get the insulation to stay and pack then from the top down to the 6' hole. You will need a nozzle on the end of the hose to neck it down a little so it increases the velocity. With the proper machine you need to lower the insulation feed rate and have all the air possible to dense pack it. You cant pack to the 3.5lbs per square foot plus density with enclosed walls.Thanks for the replies. Walls are open right now so I have all options. Walls are 10' I was wondering if I could put netting say half way up so it could be packed easier then then do the second half. If it was for hating fiberglass insulation I would go that route because installtion pretty straight forward.
Itchy? Have you used it before? I have and haven't experienced thatYes its all open, but I think rock wool is itchy also. Spray foam is too expensive plus its just a garage.
All the mineral wool I have installed is itchy. Maybe not as bad as fiberglass but itchy nevertheless.Itchy? Have you used it before? I have and haven't experienced that
If you are using the dense pack cellulose you can tell visually and by feel if there is a void. Its virtually impossible to put voids in it and not know.I would look into batt insulation like rock wool , you ensure full coverage. Even if blowing insulation is good there still might be a void.
Wet sprayed cellulose isn't dense pack. It can have voids and shrinkage as it drys.Having used rockwool several times i will never again touch fiberglass insulation. On one occasion I did find it to be itchy. I normally wear gloves and long sleeve shirts when handling it now. No more itchiness.
If the walls are open I would use rock wool. Simple, quick, and fairly cheap. My favorite thing about rockwool is the resistance to flammability.
If you desire dense pack cellulose the wet option seems to be a good choice if it is in the budget.
