Dented water main line on street side
branimal
It's not leaking…. yet. The repair sleeve was already there. This is in the areaway (the outside entrance to the basement). My main cutoff is inside the house.
I'm in an old brooklyn rowhouse and there is no street cutoff on the sidewalk or the street. The cutoff is a "tap" buried 4' under the street level.
I found a guy who has a freeze cuff machine. Plan is to freeze the line. Cut out the bad section. And replace with Type k malleable copper 1". Connections will be made with 2 Pack joint unions.
PAck joint union also know as dress couplings.
Anyone have experience fixing a main with a freeze machine?
BobnCO
I believe he simply means outside the house “toward” the street. Normally there would be a “curb stop” however and “the city” would be responsible on the “street side”of that. Yes I have watched a freeze machine work, it did!
MovingAlong
Had never heard of such a thing before but can see how it would be amazing! Be sure to share some action pics!!
Nobody-named-Olli
Make sure “the guy” knows what he is doing. Shut-off valve inside building needs to be in off position, absolutely no flow during freezing. And these freeze plugs still can fail - so know where the nearest shut-off is, make sure it is accessible and functional! Pipe needs to be completely filled with water.
Unit with closed circuit for refrigerant is safest in a situation like yours.
If using CO2 for freezing, remember it is “heavier” than air and will replace air. Not recommended at all for your situation!
Kind regards,
Olli
cgrutt
Learn something new everyday that's pretty cool. Make sure "your guy" has liability insurance and its up to date. I'd also make sure he's licensed and has whatever permits may be required. Hopefully all goes smoothly but if it goes south can't imagine costs if NYC gets involved. Good luck.
Codyboy
S.E. TEXAS
Seems like there would be a shutoff at the meter.
And if the meter is in the basement and that's the shutoff you're talking about, then is that pipe your responsibility? Seems it wouldn't be but who knows?
If it wasn't leaking why even dig it up?
Bert_
NW Iowa
The line going out to the street is always customer responsibility, at least around here.
Make sure the pipe is supported well an both sides of the coupling. I have seen lines push out of them.
larry4406
Northern Virginia
I’m guessing the water service got damaged during demo of the basement slab he’s replacing.
Water authority here as a machine that literally pinches the copper line flat to pinch it off and allow downstream repair.
Then they put a different die in the machine which undoes the pinch and restores it to a hex shape restoring flow.
I don’t know the name of the machine but it’s impressive.
I’ve seen 2 types. One was hand pump hydraulic while other was battery pack type power.
They use this when they can’t easily isolate the water line.
Codyboy
S.E. TEXAS
I've seen poly pinched off, but not copper. How would that even work?
larry4406
Northern Virginia
Black magic.
Honestly I have no idea how it works but it does!
Only seen it a few times at the day job and then only for emergency repairs when a water service lateral was hit between the main and the shutoff valve.
branimal
  • Damage is on the street side of my house main cut off. Just a few feet outside my house
  • Accessible shut off - Ordered one from supplyhouse. I'm might install it inside the house but before the meter. Initially I thought about putting it in an access box underneath the concrete of the basement landing. I think the freeze risk is too high. The access box will allow the cold ambient air to freeze the pipe i think.
  • Good advice on not trying to use a CO2. I didn't ask the guy what type of machine he has. Just checked my local tool rental place. They have the Ridgid SF2500. Can handle up to 2 1/2" pipe.
  • After pipe is repaired and insulated, I'm backfilling the trench with sand. Will have proper support.
  • I've heard the Pinch machine is the industry standard for mains. No one I've reached out to has one.
  • Prices i've been quoted:
    • $6200 replace entire copper line from street to house shutoff, with curb valve
    • replace small section $3500-5000
johnre
Portland, OR
The two halves of the copper tube essentially cold-weld into one, and the pipe separates. You do have to protect the sharp edge from hitting anything, as it will leak if damaged. Usually you put some heat shrink over it for this.
I've done this, but not for water pipes - it was to disconnect the vacuum pump attachment for a power traveling wave amplifier. It's impressive to see work and be vacuum tight.
branimal
Black magic.
Link to said black magic
Seems somewhat catastrophic to the pipe. Maybe malleable copper like my pipe would re-round a bit better.
larry4406
Northern Virginia
The pinch device I have seen in use do not weld nor separate.
It is literally collapsed flat over a pipe length of 1-2”. Then later via the hex die, the pinched flat section is converted to a hex cross section (not circular) and flow is restored.
Never a breach to the perimeter pressure boundary.
branimal
Guessing the town will bill you for tear up/redo of the street asphalt to shut the water off/on?
Of course. And that's if my tap is even functional. Many are corroded FWIR. Then they would use a pinch or freeze machine I guess.
johnre
Portland, OR
I realized that after I posted. For the power traveling wave amplifier, there is no future need to reattach to the vacuum pump, and the two halves are parted, leaving a knife edge.
larry4406
Northern Virginia
I'm not picturing how a die can reshape a crimped pipe back to a hex
Nor I Mike but their machine does it.
It’s a bad scene when water is gushing into the hole and the water authority is emergency dispatched. Labors, pumps, shovels, attitudes, etc. Then bam it’s shutoff, repaired (typically cut out damaged section, add couplings, sweat in place, then uncrimp). Backfill.
PCustoms
VT
Is it "hex" or just not perfectly round after trying to un-squash the crimped section?
WildBill
PNW
My brother has one of the CO2 freeze setups and we used it all over an apartment building remodel, was awesome. For some reason none of the plumbers around here have them, they were super jealous of it. We also did a couple of broken buried pipes in a trailer court, about six foot down. Was amazing for that as well. Super fast and easy to use, makes a cool ice donut around the pipe. I think this is the one he has, cost about $800 with a tank.
Bert_
NW Iowa
I'd be tempted to have a dresser fitting with a valve attached sitting there ready to go.
On the off chance that the frozen section doesn't hold, you could slap on the valve and then be able to shut it off.
WildBill
PNW
Thats crazy expensive for an easy to get to exposed pipe, I need to become a real plumber instead of just playing one on tv.
mike93lx
Richmond, VA
I don't want to know what the insurance costs, especially after one **** up
gizardlizard
Madison, WI
Can you use a jet sweat? I use one at work on 3/4” copper frequently and it holds back line pressure. I’ve cut copper under pressure, used the jet sweat and then added a full port valve.
545_days
Texas
That dent probably has less pressure drop that a valve. If you are not experiencing low water pressure I would bury it in sand and leave it alone.
I so l see no benefit to repairing it if it is not leaking.
FWIW, I spent my first 18 years in industry performing hydraulic calculations and sizing pipe and valves for chemical, refinery, and power plant projects. Disclaimer: I'm not your engineer, I am not a New York PE, and I have not inspected the damage to this particular pipe, so YMMV.
