Desert Garage
w33b8t1
New Mexico
Hi, I just joined up on this forum after lurking for some time. Mostly I was lurking about different building methods and interior finishes. I like the organization threads as well.
Anyway, after many years of wanting, my wife and I have decided to build a garage in our back yard.
There isn't a whole lot of room where we wanted it to go so I was limited to an 18'x30' with a 14'x18' "L" off the side. The "L" will mostly be for my wife as a craft room less a 4' chunk of it or so. The walls are 10' tall.
Pad is 5" thick. I also did a tighter rebar grid where a two post may go sometime, but who knows.
We are going to go with OSB on the inside and paint it. If that doesn't turn out then maybe like a wainscoting and some thin drywall, but this is actually a shop. No real plans for the floor. My father keeps telling me to epoxy or at least seal it. I just don't see the benefit though.?.
Our attached garage will now be the clean, tool less, hang out. We will take down the shelving and put in a couple old couches, a kegerator, and and a nice TV. That way we can hang outside/inside at the same time. It will double as a 'who gives a ****' type playroom where the kids can destroy at will (to an extent).
We hit a few snags I didn't think of.
-one cannot run THHN exposed inside and one can not run service cable in a conduit outside (at least the types that are readily available here. So I had to run THHN in the buried conduit and then put a JB in the craw space to switch cables and make it to the main panel. It was the only way I could think of doing it. Of course the inspector didn't care and didn't even ask to look so it was probably time wasted, but at least it's legal.
-The framer framed the doors about an inch short. That was aggravating. I had to cut an inch out of the headers, but they are 5.5" insulated headers so it is still fine. Plus it's only an 18' span truss system.
- I bought 1" conduit for TV and CAT5. Thought I could get three of each through that size. HA, two of each without ripping it in half.
- Windows. I cannot believe I was only going to put in two. We ended up with 9 in the end. Glad we made that change.
Anyway, we are nearing the end and I thought I would just share what we have.
Getting the ground flat.
Another shot.
Foundation done and framing started.
More Framing.
More of the framing. The whole back yard is a work in progress. We have landscaping going on, an outdoor kitchen with a courtyard wall started, a little play area with my old rock crawler cage as a jungle gym :)
Jungle Gym owner showing off our "second house".
Oh and I am building my wife a goldfish pond too. My back hurts.
Basically up to date at this point. Outside is done less soffit and fascia. The stand there will now become my outside welding table. I am going to bolt a 4'x4' plate to it. It used to be my tubing bender stand, but the garage is in the way. I thought about putting a little doggy door in the wall of the garage and running it into a 6" or so PVC pipe so I could still use the bender there, but it may have looked a bit goofy.
More
More.
Last one for now. Kitchen wall got stuccoed too.
Bib Overalls
Jonesboro, Arkansas
Interesting build. It looks like your new building works with your house to form a semi enclosed central court under the pergola. Should be a nice "oasis" when all the work is done.
Roodwerks
Phoenix
Great looking space. I'm in the middle of planning a backyard garage/shop in Phoenix, hoping to get my project moving by the end of the summer, to mid fall.
-Jon
W
w33b8t1
New Mexico
What does stucco cost for a garage that size?
Our quotes were anywhere from $4000-$5000. Garage is just under 800 sq ft I believe.
We were not wanting to spend that much by any stretch, but we couldn't justify to ourselves a different siding when we have a Santa Fe style house.
W
w33b8t1
New Mexico
Some more progress. Hopefully in the final stretch.
Needed to insulate.
We decided to osb the inside. Though lighter than drywall it still gets heavy after a while.
Walls painted and floor prepped for sealer.
Painted, sealed, and ready to start final electrical.
Minus some trim the wife's room is ready to go.
And today I am off to buy material to build shelves and do the trim work.
1921runabout
Portales, NM
Forgot to mention, I sealed my new garage floor. I'm glad I did. It just adds a finished look and eliminates dust when sweeping.
Orlando
W
w33b8t1
New Mexico
Got the trim done and started a little work bench. I have to build a couple shelves and move in this week cause next week I go back to work and I want this off my plate.
W
w33b8t1
New Mexico
I built my clear span shelf base today; a 21' shelf and two cantilevers. The beam is a double 7.25" LVL and the cantilever setups are 4"x2"x.25" tube. So the beam has support every 7'. Some online calculators suggest with a safety factor of 2 I those cantilevers will support 1500 lbs each. The seat of my pants says it should work fine.
This is just the bottom shelf, all the others will be built off of it and I will be able to store tubing under the clear span.
sean Buick 76
Edmonton Alberta
WOW, I really like the idea you executed on freeing up so much space under the storage!
I am going to subscribe to this so I can keep up with all the nice work!
W
w33b8t1
New Mexico
Looks like my wife and daughter are finishing up their side. I will get some time off work next month and will finally be able to move into my side.
