Yea, I know, makes no sense.
Here's my thought... I want a table that has the ability to move on casters, yet if I want, the casters can be "pulled up" allowing the table legs to sit on the ground. Kind of like those big moveable stairs you see in Home Depot, etc. There is a lever that you step on to make the casters touch the floor. Step on the first step of the stairs and the wheels retract leaving the unit on solid footing.
Yes, I know casters can have locks, but I've never seen any that keep the unit completely still. They all move a little bit here and there. Not good if you need a rock solid table.
One problem is I'd like to make the table out of steel and add a big vise to it. A welding table of sorts. The problem here is the weight may prohibit the "retractable wheel mechanism" from working smoothly. I don't want the table to come crashing down on the floor.
I haven't researched anything yet to see if the parts are readily available. Hopefully, it's doable.
What do you think?
What do you think?
I am trying to figure how to move my huge workbench also , probably use the casters and one jack.
