spudley
Ouch. That's more than a bit out of square. Someone needs to own up. Was the same guy that drove the bobcat in the mud measuring?
This may be a stupid question, but would it have been possible just to build the building out of square so that it matched the foundation? Would that have been preferable?Different guy measuring, but same concrete company. Needless to say, I'm not too pleased. I sent them an email and left them a voicemail yesterday so waiting to hear back. They are still scheduled to replace our asphalt driveway with concrete once the garage is finished. The pad was supposed to be above grade from our initial conversations (even with the driveway), but ended being about 12 inches below so now some grates/drains will definitely be needed in front of the garage.
Regarding the out-of-square foundation, but build crew can flash out the bottom to cover it, but that certainly isn't ideal. I'm not sure what the concrete crew would do to fix this? Perhaps knock out a few rows of the block wall, jack the back up and set new blocks inwards? I don't know much about concrete work so not sure what to ask for.
This would really upset me. How could they be off by 12 inches? That's no small error in my book. If they were off by 2 inches I'd think that was too much.
MrCole - Any updates or resolution to your project?
There are no pictures showing up for your last several posts.
Post#49 shows up. Nothing else.
Whatever you build, take lots of pictures before you insulate and put up any paneling on the inside.
They will come in handy if you ever need to add anything like 220V outlets, ports for exhaust fans or mini-split HVAC, etc.
I'm going through that now, and having the pics makes it much easier knowing where to place through holes in the wall.
Post #68 no pictures. Just the little squares.
What was the remedy or outcome for the out of square corner that you showed in the rear of the garage?
Ok ok I never have seen this thread before but now it’s added to one of my subscribed threads. If we ever move to the country, you can be sure I am stealing a lot of your ideas....only thing I will do differently is min 30Wx40D.
Definitely would do scissor trusses, two floors in the back 12’ and wide open in the front 28’ with same railing you got.
Yeah, I still wish I could've went bigger, but this was the best fit for our current property (not to mention code only allows 25% of your property to have structures and the garage put us at 24.9878%!).
Here is what I used for the railing:
Deckorators Aluminum 26" Balusters - Black - 100 Pack (Deckorators DB52613)
Deckorators Classic Black Round Baluster Connectors 200/pack (Includes Screws)
Myard PNP111902 Deck Railing Connectors with Screws for 2x4 (Actual 1.5x3.5) Inches Stair Wood Handrail (20 Pairs, Black)
