Coldstream
- Joined
- Nov 15, 2015
- Messages
- 4
I've been reading Sliderjack's thread on his TN garage. Didn't want to hijack and I've got some questions about my upcoming garage build. I hope to start in the spring.1) Wondering about footing depth, I've seen conflicting info. Per Sliderjack's thread as well as some other postings from folks even farther north than me, it seems that many go with 18" depth or so on footings. However, frost line here in MO is generally considered to be 36". Is it necessary to have footing depth to frost depth? 2) We all know that setting trusses takes several people. I hope to build this thing alone as much as possible, maybe with 1 other when needed. Why not build the garage using the old traditional method? Walls, ceiling joists, roof ridge board and then rafters. If I go 24' wide I can use a 'beam' joist length wise at the ceiling joist elevation then use 12' boards from either wall to the center. Drop some posts from the beam to the floor. Then throw some plywood up on the ceiling joists to finish building out the ridge and rafters. I know everyone uses trusses now, just wanted to get opinions. Thanks folks!
