4 Ever-Fish N
I have a couple of questions about the installation of a subpanel in my detached garage. The wire I used is #6, 4 wires including the bare ground. The distance is only 30'. Conduit was used from the main panel to subpanel. I'm not an electrician so some of my terminology will be incorrect to say the least.
Question 1. The subpanel is a 100 amp indoor Square D, mounted inside the garage. It has two hot bus bars with lugs and a neutral bus bar with lug. It does not have a separate grounding bus bar. Should there be or do I just install the ground wires to the neutral bus bar?
Question 2. I have a ground rod in the ground at the garage. Should the bare ground wire be run from the panel's (neutral bar) through the metal siding to the ground rod (with or without) something insulating the bare wire from the siding?
I appreciate any information or comments. Thanks.
