I have always wanted to do a checker board floor in a garage. Moved here a year ago and have decided to go for it this time. I bought Armstrongs VCT tile flooring at Home Depot, along with the adheisive. First step was getting the floor cleaned up using a buffer that had a stiff pad to use with degreaser. I rinsed it off with a high pressure water gun. Did that 2-3 times. Then after it dried I started from the center of the garage out. My detach is 30'x50' so it is not an overnight job. I used four 1' square tiles (same color) together, creating a 2' square. This gives it more scale since the garage is large. 1' squares would be too busy IMO. It is nearly done till I ran out of tiles. These are special order at Home Depot or Lowes and can take 7-20 days to get in. Once this part is done I plan on scuffing up the tiles with 100 grit sandpaper disk using the same buffing machine. I need to scratch up the surface so that the clear epoxy I am going to lay on top has somethig to bite to and stick. The clear coat epoxy goes on wet and looks wet (glossy) afterwards and I will not have to worry about stains and or polish. It will give it a deep wet glossy look to it. Should turn out nice. Here are some pics thus far.
I have an idea. See the bar in the background where I placed 1' squares on. The countertop acts as a bar and I was thinking about adding draft beer set up over there. There is a TV of course (satalite) and will have bar stools. That would be too cool. Wrench, TV, beer
Later in Part II need to do some neon or something. Here is a closer look. I built two spaces for my stereo speakers to come flush to the counter wall. They are the all black speakers left and right side. Pretty cool hugh? The bar counter top is solid concrete. Dn't ask how I got it up there.
