Detached garage help
kirth
I am in the process of getting ready to have my detached garage built. Its about 60' from house. I have to run the essentials to it, gas, electrical and water.
My yard is pain in the **** to work on, full of big trees and the garage will be about 25' lower than the house. The slope is pretty steep.
I live in MN so the water will be the tough one. Electrical and gas I can do with a normal trencher to the required depth.
Water of course should be below the frost line. The only way to get the water line that deep is with a mini excavator. The hill and I don't want to cut a bunch of tree roots and kill the trees.
Its nice to have water in the garage in winter to wash cars, there will be a floor drain
I was wondering if anyone has had this issue? I was thinking of going as deep as I could with the trencher, running a 3/4" Pex and putting a inside the pipe heat tape in the pipe and wrapping it and laying some high density foam over the pipe.
brewchief
You might see what a directional boring company would charge, they could pull a pipe through below the frost line with minimal damage, probably have them do gas and power as well.
u2slow
BC
I'd concern myself with the integrity and prep of the site the garage will be situated on. That burned me pretty good.
Running utilities to a building can be done later. Put some blockouts/sleeves in the concrete pour to make things easy.
Pluribus
Skagit County, WA
Plenty of trenchers out there that will do 72" depth, which I'm guessing is ok for most of MN, and there are others that can go deeper. That would be a whole lot less invasive vs. a mini-ex. As I understand it, a lot of the heavier duty ones go through roots, too. Is the slope so steep you could't use one on it?
ycgoat
S.E. Va
Some places have bed rock to deal with (we don’t in SE Va), which makes trenchers and directional boring useless. Here I use $22/ft as an estimate for boring.
dfiler2
NW Minnesota
Insulating on top of the line will work well, especially if the line runs in an area where the snow does not get removed where it is buried.
Bert_
NW Iowa
Most places that rent equipment will have a trencher that will do 5-6' deep. It's pretty common.
dcg9381
Austin, TX
I'd think you could get pex under the frost line pretty easily... You could also consider PEX encased in PVC..
For temporary water, what we did was install a hose bib without a blackflow preventer and then ran water to the building that way.
I'll give you two other options:
1) We do water collection. Our tanks are outside exposed, but you could bury a cistern.
2) Alternatively, some hangers around here do water collection to the inside of the building. A few hundred gallons, although heavy, supplies a lot of "garage water" - you'd be surprised how much rain a roof can collect.
