I have a 750 sq ft detached garage that I had big plans for but I have hit a bit of a hiccup financially so I need to use as it sits right now with out any upgrades for a while.
The original owner that had the garage built and wired used a 60A breaker off the 200A panel in the house. They ran what looks like 8 awg copper wire to the garage to a small panel. It is run in PVC conduit underground and the distance is about 40 ft from the main panel to the sub panel in the garage.
I am trying to figure out what load this can support and see if I can get by for a while before I upgrade it.
Questions:
- I am looking for the gauge on the wire but can't seem to find it. I measured it to have .228" diameter with my calipers and the only identifier I can see on it says " oil and gasoline resistant". My assumption is that it is 8 awg THHW wire from AWG diameter charts I have found and descriptions. Does this sound about right?
- Assuming it is 8 awg THHN wire, it looks like max ampacity is 55 amps. At 80% this would be cut down to 44 amps. Does this sound right?
- I want to run the normal garage tools and some wood working equipment while having the 220 v electric heater (17A) or window AC (5A) unit running. I have a delta dust collector (220v, 6A or 120V, 12A) dewalt planner (15 amps), Miller 211 welder I want to run off 220V, small delta jointer (12A), craftsman 113.** table saw (14A). Assuming the biggest draw would be while the heater is running, dust collector, and the planner, adds up to 44 amps. Lights are 4 8' CFL fixtures but not sure what wattage the bulbs are. Am I cutting it close?
Questions:
