Czar
So I've got a 200 amp main panel and was thinking I would install a 100 amp subpanel in my detached garage. The problems are two-fold. One, my main panel is on the opposite side of driveway from the detached garage. So I either have to have a pro come and tunnel under my driveway and lay conduit or run the line through the exterior garage wall, above the garage door and then outside to the detached garage... Which makes more sense? (I pretty much know the answer, but wanted to tap the knowledge base here.) Two, the run will be about 250-260' (around a shed and on the edge of the property) where I will have to trench due to the septic drain field, so what size wire will I need to account for the voltage drop?
