baneonrt
I'm getting caught up in analysis paralysis trying to finish off a permitted subpanel installation for a detached 10x12 shed I had installed a while back and was hoping for some suggestions.
Details:
Square D exterior surface mount panel. 50A is what I'm running to it, I'm confident I have the feeder circuit stuff sorted.
#6 THHN copper feeder wire running through 1" conduit from house main panel with a short underground run that's already been inspected and passed.
Plan is 3 outlet circuits and a lighting circuit.
What I'm getting caught on is how to run the circuits from the panel and into the shed. As in what fittings and any sealing methods should be used/followed.
Here is the rear of the shed. Expecting to attach the panel to the stud running along where the blue tape is. Will be installing cross boards inside to line up with more mounting points just so I don't have to rely on the siding.
Panel interior. Depending on what the proper method for passing circuits from the panel to the shed interior is I was planning on the feed passing through either #1 or #2. My preference I think would be to go straight back through #3 but I'm having a hard time determining if that's to code and if so, what specific fittings would be appropriate. An elbow fitting at #4 is my least favorite option, but if fed through #1 an elbow at #1 would be ok. Am I anywhere near the right track on this?
Thanks!
Steve
Details:
Thanks!
Steve
