67King
A few years ago, I had found a load calculator that was very detailed, but now all I'm finding are more generic calculators. Basically square footage, number of occupants, and climate zone.
I have a 1000SF storage area above one of hte garages and the kitchen. Had is sprayed with foam insulation. Had electrical, condensate drain, and refrigerant lines run in the event I decided to run a mini-split, so it should be plug and play. In the winter, it is incredibly good. Say upper 50's when it is in the lower 20's outside. That's sufficient. I'm afraid the Summer may get too hot based on some days in the upper 80's so far. I don't need "room temperature" cooling or heating. Just want to keep it say mid 50's to mid 80's. This is for storage, not living. Ceilings are 8' in the middle, and the roof is pitched, so down to 0' at the sides, making the average 4'.
May end up wanting to do the workshop, too. It is "walk out basement" grade, so below ground level on one end, at ground level on the other. 12' ceilings, about 950SF. Same general kind of thing, I don't need it to be room temperature, but I'd like some level of climate control.
If anyone has any links, I would greatly appreciate them. I'm looking at a few options, but am afraid I'd be oversizing the system. For teh attic, I'd be inclined to go wtih a 12,000BTU system. Most rules of thumb would have it about 50% larger assuming 8' ceilings and living space for 2. But I'd really like to try to check the math.
