Hey guys, I want to get some opinions. Last night I started disassembling my old Delta Milwaukee DP220 and discovered a crack which quickly turned into a break. I might have helped it a little by pulling on it in the visa a little bit. Anyways, I was thinking of just grinding the old weld off, cleaning up the area in general and using my new mig welder to weld it back together. Any reason I shouldn't? At same point I'm going to do a full restore on it!
Also, as you can see from the attached image, the C shaped piece doesn't exactly fit over the locking collar and bearing ring like I see in some pictures around the internet. Maybe the piece is bent?? When I got the drill press this piece just sat on top of the bearing ring. When I'd crank the table up the mechanism worked fine but to let it down I had to loosen the two large nuts on the back of the table column collar to let it slide back down.
