Devilbiss Compressor - 1940's
diiulio
Saratoga Springs, NY
I acquired this Devilbiss compressor, it is just a little guy. Horizontal ~20 gallon, 1/2 hp motor, and tiny cylinder. It doesn't have a regulator on it or a switch, just turns on when I plug it in, goes up to 80 psi and maintains it. Takes about 7 minutes to get up to it. It is only 120v. I put the gauge on it, only goes up to 100psi, the gauge that came with it was beat and unreadable. So, is there a way to regulate this compressor or am i stuck with just 80psi? I will probably end up selling it because I need to pick up a 60-80 gallon 2-stage unit for die grinder and other activities. If you have a nice compressor for sale in the Northern VA area let me know.
Jason
View media item 31148
View media item 31149
View media item 31150
View media item 31151
View media item 31152
Fixnair
Sapulpa OK
A switch or regulator are not necessary. You have a pressure switch which will shut the motor when the pressure is satisfied. It is adjustable and I would not set it higher than 125 PSI. You only need a regulator if you plan on painting. Then you want to set the regulator at about 30 PSI.
D
diiulio
That is my question, how do I regulate it? I realize the input of the air is where the switch is, but how is that adjusted?
I have a separate regulator and filter setup for it for adjust the pressure before the air line.
