Devillbis regulator - brass diaphragm
KenC
oklahoma
I have an ancient Devillbis regulator/water serarator. Can't find a model number or name anywhere. It uses a brass diaphragm where all the current, and recent models use reinforced rubber, but it's cracked.
Does anyone have any sources for such a thing?
I even thought about using a piece of brass shim stock to cut one. It's just a round piece but with a thickened edge where it clamped between the housing halves.
I like this one because the size of the water trap is 2-4 times the current models, even the 'professional' types
PT Doc
Can’t help with the part. But try contacting the manufacturer with a photo. I would think a company like that would provide support and try to help you out if they don’t support it anymore. Good luck.
Report back when there is a resolution. That might help someone in the future.
