Dewalt air nailer suddenly quit
killahog
Morrow County Ohio
I am in the middle of a project and my Dewalt Air nailer suddenly quit. The model is D51276 I am using the correct nails and have plenty of air pressure, no air leaks it just won’t trigger. Any suggestions?
Thanks
Git
S Cal
See if the piston/striker is retracting all the way - if not, probably a problem with the rubber diaphragm or an O Ring somewhere
KnurledNut
n/a
Check the lock off switch behind the trigger. It should be centered. If its been bumped to the right, it wont fire.
K
killahog
Morrow County Ohio
I took the back off and the piston was toward the rear, I pushed it forward and put the back on , still nothing.
seber
Deep East Tx.
Dewalt uses a plastic ring at the rear. If it breaks you are done. It is the only part not available as replacement and the first thing to go.
KnurledNut
n/a
Is this ring supposed to have a gap in it?
Yes. The piston ring is manufactured with the split so it can be installed. There is nothing wrong with it. And yes, they can be purchased, but yours appears to be fine.
But on to questions : does it leak when you plug it in? Does it do anything when you pull the trigger? Is the trigger “set”, or is it sloppy like it won’t work, not energized (on my Senco, the trigger won’t set unless the safety is made to say the tip is in contact)
KnurledNut
n/a
Is the contact tip depressing when pushed?
When hooked to air, does the trigger pressurize?
dogdog
I would look at the triggers pistons... and including that safety ...
These things works like a quick exhaust valve, so if your main chamber have air and it is not striking the smaller quick exhaust valve might be plug or not working properly. You might have to take it out and clean the ports with some sort of wires the one they used to clean welding tips or something.
K
killahog
Morrow County Ohio
But on to questions : does it leak when you plug it in? Does it do anything when you pull the trigger? Is the trigger “set”, or is it sloppy like it won’t work, not energized (on my Senco, the trigger won’t set unless the safety to say the tip is in contact)
No leaks just a little hiss when I pull the trigger, The trigger does not feel like it has pressure behind it .
Yup, if no air on the trigger, the safety may not be working, or the trigger piston is shot. On mine, when the safety is depressed, it opens an air path from the big cylinder to th back of the trigger piston.
part 22 to 30/31 I think. This link says that part is very popular.
K
killahog
Morrow County Ohio
Thank you for the link, I will order the trigger assembly and then take the gun apart. I noticed today the gun says max air pressure 120 and my compressor was set just little high at 125.
Forgottonia
edge of Forgottonia
Mine quit working a while back. The nail feeder was slightly gummed up. Now I just press downward on the nails a bit to make sure they feed in correctly. Worth a try...
KnurledNut
n/a
Yikes. 90-95 should be plenty.
Kenstone1
I run stuff somewhat "wet"/well lubed, never a problem...
might work for you
Worth a try...
