Kitt1993
Hello everyone,
I got a DW758 at a yard sale. The owner said the bearings were making noise and needed to be replaced. I decided to purchase it and tear it apart at home. Upon inspection, I found the bearings to be in pretty bad shape and after some research on Google, I was able to find a set of Timken on Ebay, After installing them and assembling the housing back together, I plugged it in to make sure everything is ok. So far there is no noise, but the housing does get pretty warm. Using a laser thermometer, The bearing is 130 degree F with no load. The heat will make its way to the center of the base and is around 110F in the middle. Again, this is with nothing on the shafts (no load) running for just a few minutes.
Is this normal or maybe the bearings are not in place correctly. I can spin the shaft freely, but not fast. To be straight forward, the shaft seems a bit stiff.
I did pop the rubber seals off the bearing before installation and added more grease as there wasn't a lot in there. So I know there are getting the proper lubrication.
Appreciate any input,
Bryan
Bryan
