DeWalt vs Milwaukee - question
Next
East Kentucky
So, I was gifted a nice DeWalt set. Started looking at impacts and some other tools like blowers and a pole saw.....
Is the DeWalt stuff that underpowered compared to the Milwaukee or am I imagining it?
Or am I looking in the wrong places?
jayemm
up high down low
What did you receive.? And, Dewalt wouldn't have it's followers and market share if their tools didn't get the job done. Depends what you got and what your expectations are. Milwaukee has a huge product line but that doesn't mean that Dewalt can't fill your needs. The big name tools can be a Ford vs Chevy thing.
finn
The UP, God's country
I have both Milwaukee and Dewalt. The Dewalt has never seemed underpowered vs the comparable Milwaukee. In some cases Dewalt is more powerful, but I’m hesitant to declare that, since they’re both continually releasing new product that is better than the last version.
They also both offer tools of tiered quality. For example, the non Fuel Milwaukee is weak, and the XR Dewalt and Fuel Milwaukee are comparable. The Black Friday / Fathers Day deals often promote weak, entry level tools from both brands.
I generally prefer the ergonomics of the Dewalt.
jayemm
up high down low
Good reply. You elaborated points that I wouldn't have thought of.
dnschmidt
Phoenix, AZ
As is typically the case neither is better than the other at all things. Milwaukee has some duds and DeWalt has some duds. It's all tool specific. DeWalt has some great stuff like their new plunge router that's miles better than Milwaukee's equivalent. Whereas there are some Milwaukee tools that exceed the equivalent DeWalt.
kbeefy
Harington, Eastern Washington
Both nice, both have lots of offerings and lots of fans.
They are both top-tier tools, I don't think you can go wrong with either one.
As mentioned, they also both have budget lines. Make sure you compare apples to apples.
liliysdad
When I had to pick a team, I chose yellow simply because it’s the predominant color for contractors and the trades around here. This means that the selection in the local pawnshops is much better.
rsanter
visalia ca
Dewalt and Milwaukee are the two top,tier tools out there.
i don’t think you can go wrong either way.
with that said I am fully in the Dewalt camp and they have been great for me
impactims
Milwaukee also has a pro grade line of tools…..M18 fuel. Is this what you are comparing to or are you comparing to M12?
If you are comparing to M18 fuel, not much out there will compare. Even dewalt atomic would have a hard time competing with M18 fuel.
If you are talking about M12, then any dewalt should be comparable. M12 is entry level.
impactims
But yeah, you need to be more specific with the models you are dealing with. You can’t just say Milwaukee and Dewalt. Not enough info.
Both are good. But M18 has the edge for raw power and speed.
Rinspeed
NY
As a typical homeowner you will never see much of a difference between the two. I will say as someone that had a staff of thirty people that used cordless drills hard daily the mid grade Milwaukee hold up much, much better than the Dewalt.
willf650
I have some of both but more of the Milwaukee because their line seems to be larger. I also like the form factor of the M12 line compared to the 12v DeWalt. The 12v DeWalt line is very limited.
Either are good and each have their different tiers of quality. They have what would be considered homeowner stuff and also contractor grade stuff.
The batteries are generally what determines what people get. Basically whichever brand you have the batteries for is what you buy.
I recently bought a DeWalt right angle drill and a Milwaukee battery adapter. The DeWalt drill is better than the Milwaukee equivalent and I only carry Milwaukee on my work truck and don't want carry another set of batteries and charger.
exmaxima1
Midwest
I like Milwaukee M12 for smaller 12v tools, but Dewalt for the larger 20v stuff. The Dewalt Atomic 1/2" impact is especially nice for working on the car.
finn
There are also entry level M18 tools from Milwaukee, so you can’t go solely by voltage.
A Quick Look at the current Home Depot flyer shows deals on M18 brushless tools, but they aren’t the Fuel version, but rather simply brushless. These would be considered more homeowner level M18 tools, built and spec’d to a price point, rather than Premium Fuel tools.
Dewalt tools in the flyer follow the same pattern. The 20v tools being promoted, while brushless (I believe), aren’t the Premium XR versions .
Same with batteries. Both brands offer a couple of grades of batteries at different price points.
I mostly buy the Compact Atomic and XR series Dewalt, and M18 Fuel Milwaukee when adding tools, but also buy other brands, knowing they likely may not be equivalent, although they, so far, have done the job I bought them for. I haven’t yet been disappointed with any of my cordless tool purchases, regardless of brand. I currently have eight active battery platforms, and, from memory, have phased out four more over the last forty years.
CapriMikeC
finn
That's an excellent kit to start. I have all DeWalt stuff because a friend can get it at significant discount. Modern cordless tools are remarkable compared to even 10 years ago and most will beat the "best" contractor from back then.
For some good info, check out Torque Test Channel https://www.mcmaster.com/2752T16/
That’s why I cringe whenever I read the “Buy once- Cry once” credo. It rarely pays off to hold out for “the best”, in someone else’s eyes, when entering a field where technology is changing.
Buy what you feel you can afford at the time. Whatever you choose will probably be superseded by something better before you wear it out.
I have several twenty year old SnapOn ratchets. I don’t think they’re any better than the Gearwrench ratchets I bought last year. Does that mean I shouldn’t have bought the Snapons back when? No. Just that technology is a moving target.
impactims
M18…..M18 FUEL.
Not the same and I specified FUEL.
finn
M18…..M18 FUEL.
Didn’t say you didn’t specify Fuel.
The difference isn’t obvious to everyone, and certainly isn’t pointed out in the HD ads.
A knowledgeable consumer of tools would see the difference, but I bet the vast majority wouldn’t, as made clear by some of the posts by newbies on this site.
impactims
Hmmm, if the product says fuel, then it’s fuel. If it does not, then it’s not M18 Fuel. Saying fuel on it and the hefty price tag of the fuel should give it away pretty easily.
I guess some folks may not catch those details.
Oggy
Central New York
This is exactly like the ford vs chevy debate, there's always one more thing the other has that this one doesn't...
If it were me, I'd buy a battery 2 pack and get the tool for free. They're typically higher quality than what's included in the packages, and usually a higher AH. Actually, when I needed (wanted) a cordless saw, this is exactly what I did. Good thing too because man did I run through batteries building my deck...
finn
Some folks don’t know the difference between a ball peen hammer and an and a framing hammer. That doesn’t make them inferior to me or you.
impactims
Ok, but I think you might be underestimating peoples ability to detect wether or not the box and product say M18 FUEL on it. And, folks might also detect that fuel is twice the money. That might be hard to miss.
Kscardsfan
The Little Apple
Sir, you have no idea how amazingly stupid the average American is. The only positive I can say about the ever increasing decline of human intelligence is that is excellent job security for myself and other first responders.
SouthernIllinois
Carpentry stuff - Yellow
Mechanical stuff - Red (with the exception of a Green 14.4V Snap-On impact I just ordered, I love that paddle trigger)
allinon72
Indianapolis
Dewalt stuff is fine, it's just not king of the hill anymore. For many years it was, starting in the late 90s (my estimate) and into the 2010s, it was the top dog and nothing really came close. Their problem is they didn't put any effort into their batteries, Milwaukee started creeping in with some very compelling battery tech for the time, matched or exceeded Dewalt's build quality and vast tool lineup, all the while Dewalt just kind of sat back and let them do it without a real attempt to compete. Once Milwaukee started to tip the scales, their marketing prowess was the final nail in the coffin (not really, DW is still wildly successful, just not the top choice of most trades). Fascinating story really. Milwaukee just kind of bullied their way into the game and never looked back.
sparky 1971
Central Iowa
I am almost all Milwaukee simply because it's easiest for me to get. I've used DeWalt impact drivers and drills and I can't tell a difference in performance. The Milwaukee feels better to me but that may just be because it's what I'm used to.
subroc
Dover, NH
That is a nice kit. Brushless tools. Also of note, that is a 565 circ saw instead of the 566 that is usually included in kits. The 565 is the better saw. it has a magnesium shoe and a rafter hook. The 566 has a stamped steel shoe and doesn't have a rafter hook.
The only negative in that kit is the 2A charger.
I have Dewalt, Milwaukee and Ridgid. I like them all. I have had the Dewalt stuff since my 14.4 drill so I am partial to Dewalt.
I expect you will be pleased with the tools in that kit.
As far as the impact wrench, HD has a BOGO going on now. Might be worth a look.
jar944
Northern VA
Hard to keep to just one platform. Imho the dewalt miter saws and routers are mutiple levels above milwaukee. Circular/recip saws impact/drills and ope milwaukee has the edge along with the m12 line.
So you really need both
BlakeTheCarGuy
Roanoke Virginia
A few years ago I’d of said Dewalt was underpowered but now their stuff can be top dog. I still have Milwaukee because that’s what I started with and like and works great and the best but Dewalt does the job too. At my dealership Milwaukee outnumbers Dewalt by a long shot.
1Bad55Chevy
All the mechanic type tools are m12 so I dont think thats a fair statement. Also not all m12 tools are made in the 18v line and vise versa. The m12 tools are smaller for different applications its not a quality difference.
finn
I don’t think that’s true.
Dewalt was first to introduce the pouch battery technology with the Powerstack a couple of years ago. I might be wrong, but I don’t think Milwaukee is there yet. The pouch technology yields more useable power out of a compact package.
Pretty sure Milwaukee was the first to abandon stem type NiCad batteries and go to modern lithium sliders while Dewalt held on for several years. On the other hand in the 12 volt line, Milwaukee is still clinging on to the old stem packaging.
tiredoldironworker
I'm an ironworker foreman. We use all Milwaukee power tools because of the 5 year no questions asked warranty. If you read the fine print on the DeWalt 3 year warranty it states that ANY tool used in a professional environment is only warranteed for 90 DAYS! Some of my Milwaukees were built in 2007 and still work fine!
allinon72
Indianapolis
You're correct, Dewalt came out with their Powerstack batteries, but that was after sitting on their hands and letting Milwaukee kick their *** and steal a good deal of marketshare over the course of 15+ years. It was too late....on every job site I see 10 M12/18 batteries for every 1 Powerstack battery.
finn
You’re exaggerating. Milwaukee rolled out the M18 line in 2005.
Dewalt introduced their now standard 20V Max line in 2011.
That’s nowhere near 15 years. They had 36 v lithium batteries as early as 2005.
Ohio Andy
Columbus, Ohio
The kit I was given
Looking for 3/8 impact.
I would say at this point you are strongly in the DeWalt camp.
With that kit you have no reason to go anywhere else...
I own an older Milwaukee and without thinking. I bought some Milwaukee m18s so I'm on two different platforms. An 18 and whatever the other one is 28 I think
Then I was gifted a bunch of Ryobi stuff, and I own some festool .. I have four battery platforms...
PlanB
Saskatchewan
I wound up in the dewalt camp with a drill/driver combo without much thinking. I spent some time second guessing that decision but as time went by it seems all the brands have kinda converged price/quality wise - at least at the home owner level.
As an aside we had some contractors in earlier this year, they were mostly beat up old Makita stuff. The one specialist (old guy) they brought in to finish was brand new out of the box Ryobi.
At this point I'd chose a colour and realize this probably isn't a buy for life area of equipment.
