diagonal pliers, recomend me some
sko
Los Angeles
snips, dikes, or side cutters, everyone calls them something different. i've got a pair of channel lock cutters, that are doing the job, but, when i'm cutting 1/4" cable (which is 80% of what i do with them) they don't seem sharp enough, even tho its squishy stainless cable. are there some better ones that stay sharper longer or are made from harder material? or do i need to man up and squeeze harder? what do you guys recommend.
MrMark
Southern Cal.
I think you need more than side cutters for that application. I would consider that abuse. You should use the Knipex mini bolt cutter. They are designed for that thick of a material. The best side cutters I have are Snap-on and Klein and then Knipex. This is one area where Klein does shine. But again, I would never subject quality side cutters to that type of abuse.
Monte
Germany
1/4" squishy stainless cable ?? :shocking::shocking::shocking:
I don´t recommend diagonal pliers, there are cable cutters for that task.
wilb1976
Maui
I install elevators and I use dikes often and I wouldn't recommend dikes for 1/4" stainless steel cable, although the blue handled Kleins that I use are very good. My co-workers who don't use the Kleins use the high-leverage Knipex. We use them quite a bit when we install the elevator doors but we're only cutting 1/8" wire rope. For any 1/4" - 5/16" wire rope we use these http://www.usrigging.com/cutters.html and for any thing larger, like the cables that hold up the elevator 1/2" - 3/4" traction steel wire rope, which is harder to cut then stainless steel cable, we use these http://www.wurtec.com/asp/product.asp?Item=16-140
mrholeshot
MEMBER EMERITUS
If you are cutting 1/4 stainless cable with Channellock side cutters that says a lot for channellock, lol
Stuey
28m above sea level
I couldn't find a Channellock for steel cable, all I find is for copper and aluminum. do you have a source?
You're right. The one I was thinking of for wire is for "soft metals". I've seen them cut through thin gauge steel, though. Sorry for the confusion.
In that case, I'd look for a Park bike tool cable cutter, or a small bolt cutter.
