Dial indicator stand recommendations
b7labelle
Through a mixture of alcohol and eBay, I have acquired, among other things, 2 dial indicators:
https://imgur.com/a/XW6MmwZ
Looking for recommendations for a magnetic dial indicator stand that fits my older dials. I’m a home gamer, so I’m not looking to pick up a industry grade mount, but at the same time I’ve looked at some of the junk China is shipping and I don’t want that either haha.
My goal is to measure the runout in my drill press.
The larger indicator has a .247” diameter mount, and the smaller one has a .185” mount. The smaller one also looks like a 1/4” rod could slide through the knurled but and held with a set screw.
A lot of indicator stands I’ve looked at seem to be made for 8mm mounts, which I’m concerned wouldn’t work with these two older indicators.
Is there a mount someone could recommend, or would I be better off just picking up a newer dial/stand set?
Chevy-SS
Rhode Island
Here's the two (pic below) I use most often. Mostly I use them for measuring rotor runout on brake jobs. They are Chinese but they work GREAT! The magnetic mounts are incredibly powerful. I've been using these for years with zero complaints.
Starrett is a terrific brand, no doubt, so I might try to save those old ones. But if it was me, I'd just pick up a whole new kit.
dr_clyde
Holland, MI
All my indicator mounts are Noga, I can’t stand the traditional twin beam style. They’re probably more than you want to spend for occasional use though.
txvwnut
Bedford, Texas
Noga. I used the twin beams for years as that’s all there was then the Noga came along. You won’t find a better mag mount for a dial indicator.
Downwindtracker 2
BC
Even the Noga clones are costly, but well recommended. I've used Mititoyo(sp), Tedclock, Starrett,General, and Chinese ones. Get a Noga and be done with it.
dr_clyde
Holland, MI
I’ve looked at the Nogas, but I’m not sure they’d fit these indicators.
I have both of those indicators, and there are ways to hold them on a Noga. I’ve made adapters for mine, but I’m pretty sure Noga makes factory ones.
Those are really common indicators, so I would think Noga makes a part for them.
I’ll have to look in my book.
b7labelle
Thanks, I’d appreciate that!
2ndGearRubber
Pittsburgh
I purchased a Noga, based on reviews here. I use it primarily for rotor/hub runout measurements. I "magnet" it to calipers, struts, rack arms, whatever. I'm pretty happy with it, I wish they made a vice grip mount for their mechanism. Sometimes there isn't enough solid ferrous metal around for the magnet to grab well.
L.Cheapo
Noga makes Kant-Twist style clamp bases. I'd imagine with a welder and a cheap pair of vise grips one could make their own. I believe some of the Noga arms are threaded into their bases.
I'm a Noga fan too. I don't use it often, but when I do I'm glad I went with Noga.
matt_i
My opinion is you don't need an exotic clamping mechanism. Just a drilled hole, drill and tap into that hole at a 90 degree angle and use some pressure screw to bear on the OD of the rod that slides thru. Can go exotic and make a "wing bolt" by welding or brazing to a hex head or socket head cap screw or just tighten with screwdriver, allen wrench, or open-end wrench. If you are super concerned about scarring the OD of the shaft then use a brass screw. The existing shaft sizes are already perfectly setup for standard sized bores, drill a .250" hole for the .247" shaft and a .187" hole for the .185" shaft.
When measuring runout in the spindle don't just turn the spindle by hand. Lock the quill and side-load the chuck or spindle and see how much you can deflect the indicator in various directions, no rotation needed. The true amount of clearance in the bearings isn't seen by just rotating the shaft and allowing it to self-center.
2oolhound
BC Canada
Just a word of caution, I've looked at the chinese ones we have at the Canadian version of HF which is Princess Auto. If you sneeze you'll knock the magnetic base off it's position. I have old old used ones that have way stronger magnets. Check before you buy.
b7labelle
Good tip, thanks!
b7labelle
I guess I’m not so worried about picking up a decent brand, but rather if the newer stands would hold my older indicators.
Steve_P
I have two 20 yr old Mitutoyo stands and like them a lot. Before that I had a generic Chinese one and there's no comparison.
