Hey folks, I am looking to purchase a good quality dial indicator. The first need will be to set up the gears rebuilding a differential. Other uses down the road could be to measure warpage on rotors, and other general shop type uses where a dial indicator would be handy.
I'm not currently set up for machining parts, so that type of high precision work isn't likely on the horizon for now, just general automotive and heavy equipment repair applications. I've got a set of Mitutoyo calipers and the quality is excellent on those, so I am leaning towards Mitutoyo for the dial indicator as well. Will also need a magnetic base or some other way to mount it to surfaces.
What has me slightly confused is all the options when it comes to dial indicators, now I realize there are specific applications where certain types are needed, but what type do I need for general applications?
Here is the table of different types I am looking at on Mitutoyo's website:
https://ecatalog.mitutoyo.com/Dial-Indicators-Series-2-Standard-TypeInch-Reading-C1216.aspx
Which one should I be choosing? This is showing the series 2 style in inch readings only. I don't think there would be any reason for a compact series 1 or larger series for what I plan to do?
Any help on this subject would be greatly appreciated
