Greetings,
I have a beam type torque wrench but I’d like to upgrade it to a memory dial type. I’m looking at CDI but open to other options.
I see torque values on common gears ranging from as low as 5 in/lbs to about 35. The lowest values are when reusing the bearing which seems silly. If you’re going to rebuild something actually rebuild it.
The wrenches come in either 0-30 or 5-75 range. It seems with the 20-100% accuracy range that the 30 max one is better for this purpose. I know the GJ answer is buy both but let’s answer the question which one is most useful to buy first. Budget is about $150 so I think electronic is out.
Suggestions?
Suggestions?
