Dialing down a torque wrench
bobcatdan
Kaukauna,WI
After talking with the guys at the other shop in our dealer chain, where do you dial your torque wrench to when done. I go to the lowest setting, ie 5 ft lbs. The other two guys said alway down completely to remove any spring pressure. I said you shouldn't crank one all the way down. Who is right?
Gregg33
Port Colborne, ON, Canada
I have a licenced mechanic friend who whenever he uses a torque wrench he dials it down way below the minimum setting (and I'm guessing he's never had any problems doing that or else he would have changed his practices). However the instructions that came with my made in the USA Gray torque wrench state the following "Store torque wrench in it's protective case at it's lowest torque setting. Do not force the handle below lowest setting." So that's what I do.
