Diamond Cup Grinding Wheel
pattenp
Virginia - USA
Which one of these cup grinding wheels is the best style to use to grind down concrete. I'm needing to grind down a high spot (about 4 sqft) on a garage floor about 1/2" to 5/8" down.
mooman
CHICAGO, IL
the first one. I would be helpful if you had someone there with a Shop Vac sucking up the dust as you go. And don't forget to wear a mask.
Packard V8
Spokane, WA
Suggest using water when grinding concrete. It's a helluva mess either way, but the water slurry is more easily contained than the airborne grit. It also prevents the worst damage to eyes and lungs
thnx jack vines
