Did anybody use torx bit on hex bolt?
gtlaw
I've used a slotted screwdriver on a torx screw a few times
dirtmister16
wisconsin
ive done it, it works. not right but you do what ya gotta. sometimes i use a larger torx bit and tap it in the allen cuz the allen stripped. but i only use cheap bits for things like that.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Yes, quite often and fully intentional.
MBs from the eighties have galvanized grade 8 M8 hexhead screws for attaching various external parts to the cylinder heads, which are aluminium. Over time the bolts corrode and get stuck, real hard. So hard that a hex bit just rounds the hex. Hammering in a TORX bit in the rounded off hex hole has saved the situation for me several times .
And even though many of these cars are junkyard bound within a few years, they are rusting really bad,I always clean the thread in the head and put a dab of grease on the new bolt.
Ola
Holt
Bellevue, Nebraska
Yep use a t25 security tors screwdriver for a 5/64th security bolt at work. Have the special bit but I wanted a driver with handle and no bit. Wanted wera and they don't make it so t25 it was. Works great and never strips.
richfinn
Leeds, Yorkshire, England
I use Torx bits as screw extractors quite regularly (it pisses with rain and they use a lot of salt on the roads in the UK) they work really well on rounded out hex heads if you hammer them in with a soft faced hammer. I use a cheapo Halfords (probably like sears) set that they will warranty without question.
We have a particular problem with spark plugs shearing off in the cast Iron cyl head of some Brit Fords and a Torx bit works great at getting the broken shell of the plug out.
marlinspike
Virginia
Ola
What brand in-hex sockets do you use? I had that same problem with those same bolts, until I switched to Stahlwille, then I never rounded one again.
cheechi
Triad, NC
I did halfway on purpose just the other day. I noticed it was hex, grabbed the wrong set of wrenches (the swiss army type) and just said f-it, it was just a set screw T25/4mm something small like that. Too lazy to walk 4 steps, if it had stripped i would have deserved it.
