Die Grinder Attachments
quilty
Just recently picked up an M12 FUEL 1/4" Right Angle Die Grinder and I'm wondering if there are any quality attachment kits out there for sale? What I mean is a bundled kit that will at least get me going with a variety of attachments such as cut off discs, roloc dics, etc...
Would be nice if it came in some form of a case for long term storage. Typical use will be light duty automotive and fabrication.
Thanks
Dave455
Sussex, England
There seems to be a bigger difference in the quality of die grinder attachments than those for almost any other tool.
For every decent quality stone I’ve found, I’ve encountered another that disintegrates when you touch it to the workpiece. Sadly, most of the kits I’ve seen contain parts of the latter quality, and they’re not worth considering.
It’s not what you want to hear, but unless anybody else has found different, I think the only way to go is to buy good quality burrs, stones, Roloc’s, whatever from a reputable supplier (I use a few, but MSC are good) and build your own “kit”
I’ve seen kits of different stones, and obviously sets of burrs are common, but I’ve never seen mixed kits, as all this stuff comes from different manufacturers. Buy yourself a compartment box and fill it as you go.
One cautionary note - good die grinder accessories are expensive, but poor ones are frustrating, and can be dangerous. Once you’ve used decent ones, you will wonder how you managed without!
dutchgray
Dorset. England.
As above buy what you need from reputable names and make up your own kit, you most likely don't actually need to have that many different accessories.
GeoBruin
I know a kit is tempting, but the kinds of consumables you're talking about (roloc discs, cut off wheels, bristle discs, etc.) go very quickly and almost need to be purchased in bulk, especially when you talk about using them for fabrication.
While a kit let's you try out several different things, you only get a few of each, and you'll find you end up blowing through the ones you use most in like 1 job.
I would invest in a couple good (concentric) 2" arbors/backing pads in either TS or TR (or both so you can use whatever kind of discs go on sale) and a cut off wheel arbor or two. Then cruise Amazon or the Warehouse for boxes of 3m or Norton resin fiber and surface conditioning discs. You could also join the mailing lists at Benchmark or Empire Abrasives and get coupons or deals on their versions.
If you're starting with absolutely nothing, finding a kit that also comes with arbors/backing pads as well as a selection of different discs might be worth it. In general, 3m Roloc and Norton Speed Lok are compatible in either TS (type ii) or TR (type 3) variants.
Good luck.
cherrybomb
Near Madison Wi.
Carbideburr.com is a good source.I agree sets usually have some that you won't need.I have a few favorites,for steel and aluminum takes a different design. I then order a few extras, fresh bits are easier on tool and leave a nicer finish
Steve_P
Project Farm did a test on carbide burrs, so give that a look if you want to buy a set. I've bought burrs in singles over the decades; first from Enco, and then from Harry Epstein- all high quality. Enco is now MSC, so the bargains are unfortunately gone. But high-quality burrs are still reasonably priced on Epstein. I buy only double cut carbide burrs as I've had the single cut's chip. Yes, aluminum uses a different design with much wider tooth spacing to prevent clogging.
There are lots of good generic roloc type scotchbrite and sanding discs on Amazon. I just buy them there when I need them. Just be aware that there are several different mounting methods for the pad onto the backer.
Nofries
Charlotte Area
I like Benchmark, seems to be a fair middle ground. Still not exactly cheap but quality is better than most local big box stores. They often run some good sales, 10 flap disks for $10. Mostly to get their foot in the door, but I haven't been disappointed in anything I bought from them. Plus you get a free sticker. LOL
Steve_P
I've bought a lot of Benchmark stuff on Amazon and I've been satisfied with all of it. Yes, not the cheapest, but good enough for me as I rarely pay the 3M prices. For home use it's no big deal to me if a product lasts 80% as long and costs half as much. Especially if I can change it out in a minute or two. For a business, maybe it's worth paying more for the best; but I've even been pleased with all of the well rated but generic sanding belts I've purchased on Amazon.
