Die Grinder
bacpacker
East Tn
I've been looking at Die Grinders for the shop. Locally the 2 brands I keep seeing most are Ingersol Rand and Campbell Hausfield.
To me the IR's seem to be much better made of the 2. Comments or suggestions for other brands gladly accepted.
:confused:
Daves69
Kernersville, N.C.
Florida Pnuematic made in USA. Has good torque
http://www.wttool.com/index/page/pr...uty+Die+Grinder&update_continue_shopping=true
Elroy
kentucky
I've been looking at Die Grinders for the shop............
If you want a real die grinder, get a Dotco
Retailing at about $500 a pop, they might be a little steep
In that case Elroy would recommend a Chicago Pneumatic
Be advised that IR has several levels of Die Grinder quality available as well. Their "home owner" grade isn't that great but their industrial line is much better. You simply get what you pay for. A Campbell-Hausfield would rate below home owner grade in Elroy's book
Ritter4.0
Maryland
I have an Aircat 90*, a used Sioux straight, and a mini Kobalt straight. The Aircat is decent, but the gears are noisy. The Sioux is easily as old or older than me (I'm 20), and works flawlessly.
The Sioux looks just like the Dotcos that have been posted, but red.
The Kobalt is one I bought to play with and try to silence. Its much quieter than both the Aircat and Sioux now, but lacks the torque that the Sioux has. It came with an 1/8" collet, so I've been using 1/8" tools in it. If you want I can pull it apart and show you how I silenced it.
I have under $150 between the 3.
senlow
Wheat Ridge, Colorado
Damn right. My oldest Dotco has a housing that the ribs are nearly worn off, and you can hardly read the name. It's been worked hard, and still runs great.
Skin
Boston
If you want one to clean scale/gaskets you dont need anything expensive. There are also usually 2 styles. Smaller ones for the above mentioned tasks and larger ones for heavy duty grinding/cutting.
rlitman
Long Island
My only 90 is dedicated to roloc use.
I keep a 1/8" collet in my smaller straight grinder, and 1/4" in my larger one. They mostly see carbide burrs.
Hate to burst anyone's bubble, but Campbell Hausfield is no better than Harbor Freight. Just more money. (Not that I've had bad luck with HF die grinders mind you, but I'm not paying more than $8 for one).
LWaite
Denver
:thumbup:
DrkMtnDew
If you can find it or order it, get the IR 3108. If that is a little more than you are looking for or if availability is a problem, any IR will be better than CH IMO.
bacpacker
East Tn
Thanks for the input guys. A few brands have been mentioned I'm not familiar with, so a little research is in order.
The Dotco's sound great, but for no more than I will be using it $500 is kinda steep right now. i just need it for light grinding and occasional cutting of thin metal.
The CP Elroy mention looks very similar to an old air drill I have. That thing is 30+ YO and still works great.
Thanks again for the input!
diesel research
gulf coast, TEXAS
Watch out before assuming that. It is about as safe to assume as "pittsburgh pro" being made in pennsylvania.
Some florida pneumatic is made in the USA. Most of them are expensive and labeled "universal tool". Even some universal tool is made overseas. For $50 you should not be surprised to find Taiwan or even china...
Florida Pneumatic has been manufacturing, importing and distributing air tools and related accessories for over 40 years. Our U.S. and overseas made product lines have enjoyed a well-deserved reputation for superior quality and performance.
JayL
Manila, Philippines
At that price range it is pretty much guaranteed. Hell even at $100 it is pretty much guaranteed.
You're right price more often than not is a good indicator.
In fairness the Sioux die grinder seems to be above the generic ones I see. Has good power at 0.5 HP rating. Heavier and a bit longer than the IR 308. Time will tell if it will hold out well too.
sberry
Brethren, Michigan
I bought a straight one at HD, Husky, about 30$ and its been super, I believe its the same as the Farmhand at TSC, the same model is sold under a couple labels but it has been great and my shop is busy, it gets used. Those CH things for 19$ do work and can earn their keep but for another 10 or now maybe 20 these are a really durable unit, I for one am not going to spring 500 for one thats for sure. The sander in the pic,, first one last 20 yrs, this one 10 and I put a stock bearing in the head, works again and the right angles are REALLY good, have 3 or 4, never, never so much as had to tighten a screw in one,,, got one or 2 with hundreds of hrs on it,, for 60$.
71flh
There are always coupons for $7-$10 HF ones. For that money I figure they're worth getting, although my US made $10 swap meet die grinder is my favorite because of the power and great sound...
Daves69
Kernersville, N.C.
I think the black composite ones are made in USA
