crazybrit
I have a Bosch angle grinder but for other grinding work I'm using a Dremel. The 1/8" shaft isn't ideal as it's easy to bend burrs plus I worry I'll burn out the Dremel.
I'd like to get a Die grinder.
I like the variable speed of the Dremel and I like that I don't have to turn the compressor on.
The compressed air ones I've used before have all been cheap and fairly binary. Even when they're supposed to be variable I've not found the paddle control that effective at controlling speed.
Wondering if I'm better off investing in an electric corded unit like a Metabo which is variable speed (https://www.amazon.com/dp/B00FDLB9OC/?tag=atomicindus08-20)
Or if there is a decent variable speed compressed air unit available?
Or some other alternative?
