Die to clean up these oddball puller threads?
relic7680
Northeast Florida
I have a military surplus Armstrong-Bray puller set, and the end of one shaft is chewed up enough not to let the arm come off it. I would have just run a die on it by now, but the threads are oddball. It seems that the pitch is not uniform...one side is sloped and the other is straight up. Can anybody tell me the name of this type of thread or where I can get a die to clean it up? The shaft is 3/4".
mvptrukin
Denver, CO
Most pullers with a 3/4" pressure screw are 3/4"-16 ( like Snap-on) but the only real way to tell is to use a thread gauge-the only other size it could be is 3/4"-10. Most tool companies sell rethreaders in sets but Snap-on sells individual ones for $3 or $4. I saw your other thread about this puller set--what did you pay for it? I wonder if it was made by Armstrong tools or another company for a government contract.
toolchaser
Greenville, GA
It's probably a ******* thread pitch, you can use a 60 deg. thread file or just grind off the buggered threads, its not likely you will ever have the center rod in that far anyway. It was probably mangled up by pushing against a blind hole.
Provincial
Near Salem, OR
It may be a buttress thread. Google that and compare the images to your piece.
You will probably have to take it to a machinist and have him set up the screw in a lathe. He will have to grind a tool bit to fit the thread, and recut the damaged threads. It will take a lathe big enough to clear the puller arm, since it looks like it won't unscrew past the damaged threads.
DocsMachine
They're called "Buttress" threads, and, unfortunately, dies to clean or cut them simply don't exist. The quick and dirty fix would be to carefully grind those threads off- they're near the end and won't take up too much usable working area, and even "cleaned up" wouldn't have the same strength as the original thread anyway.
The proper fix would be to have a machinist carefully recut them in a lathe- even though, as above, that section wouldn't be as strong. Might be better to have somebody with a lathe carefully turn that section down, get rid of the damaged threads entirely.
Doc.
R
relic7680
Northeast Florida
Thanks fellas. I'm in school for auto restoration, and we have several lathes, so I think I'll just smooth the end out that way. Several other shafts in the set just have regular 3/4-16" threads, but others have the "buttress" type like this. mvptrukin, I think I have less than $80 into the entire set. Armstrong doesn't currently make one like it (at least not offered to the public), so I suspect that it's military only.
mvptrukin
Denver, CO
I didn't look at the threads in the pics that closely like the other members did--most pressure screws are interchangeable so you can use them to pull off or push on. It's my understanding that with buttress threads you can only apply a load in one direction in this case as a puller. It makes sense they didn't match up with the other pressure screws. Proto uses a rolled Acme thread on their pullers.
lzenglish
California
I don't see any threads left to dress up. I would chuck it up in the lathe, and
delete the last five or so bad threads, to the smooth end diameter. If that smooth end lenght is critical, you may have to cut off and reface the end of it.
PS. I saw this tool for the first time, in a catalog, and may just get one. It is called a "threadmate", and chases up to 1/2" dia. threads.
Wayne
