Diesel Injector cleaning, any recommendations?
Hawk321
Germany
Hi Folks,
I need infos about how to use a ultra sonic cleaning device. The purpose should be the high end cleaning of unit pomp and common rail injectors.
Well what do I need...which cleaner is the "best" and what should i do after the cleaning??? I mean...It's mandatory to remove all the water and cleaning fluid from the fragile injector also to relube it befor i mount them back.
Any experience??? Please consider UI and CR no old style injectors!!!
My inquiry to some diesel test equipment manufactors are all the same...
"you need to buy a ultra sonic cleaner, than a sterile cab and a testbench...will cost you aprox 150.000€"...
well that maybe the perfect way...but serious...in real life it's ********.
nso123
Dunlap, TN
Did you buy the equipment? If not, there are companies that specialize in cleaning and flow testing injectors. I can't tell where you are, but if you are in the US, I can get you the info for a company local to me that does this service.
