metlmunchr
- Joined
- Sep 10, 2011
- Messages
- 1,289
A standard cubic foot of air is one cubic foot at 68°F and 14.7 psia, or 0 psig.
A cubic foot of air at 90 psig and 68°F contains roughly 7 cubic feet of standard air. Only 6 cu ft is deliverable as pressurized air, while 1 cu ft would remain in the tank at 0 psig.
One deceptive claim you still see from time to time, usually on cheap compressors, is advertising piston displacement rather than air delivery, because displacement is a larger number.
A lot of what I've seen recently is advertising max psi and tank gallons, neither of which have any bearing on the actual ability to deliver compressed air. In fact, many posters here on GJ seem to refer to compressors by tank capacity alone. i.e. I wanna buy a 60 gallon compressor. Gives no more useful information than saying I wanna buy a truck with a 60 gallon tank. Would that be a F150 with an auxiliary tank, or are you shopping for a tri-axle Peterbilt?
In general, the faster the compressor runs, the greater the pumping losses. That explains why a pump driven by a 5hp motor at 1400 rpm may deliver 15cfm while another pump driven at 900 rpm by the same 5hp motor will deliver 18 CFM.
