Difference between distilled and deionized water for auto use?
Meursault74
Southern California
Thanks. I'm not a chemist so I won't go on but I am surprised that DI water and distilled water can corrode metal unless it contains dissolved oxygen, CO2 or other contaminants.
Hydration of aluminium oxide is one process, but that is very slow.
I guess I'll just have to remain surprised.
Jack
Any pure water exposed to the atmosphere will have carbonic acid (dissolved CO2).
I remember exhaling (CO2) on solutions with pH indicators to make them change colors when I was a student.
Even if the pure water didn't have any slight acidity in a closed system, it would leach metallic ions slowly into the water.
We filled a machine cooling system with 18M-Ohm water and the system still needed to have the deionizing resin beds in the system changed out periodically. We knew when the resistivity got too low we'd got some slight electrical arcing in the system. The metallic ions in the water allowed that to happen.
Jack Ryan
Adelaide, South Australia
Thanks again and yes, I understand that.
Meursault74 said:
The water has no metallic ions in it and has a better ability to leach them out from the metal surroundings over time.
The implication here was that those contaminants were not required.
Anyway, all good.
Jack
Sumboodie
AK
It's more for half the coolant.
I was factoring that.
Case of 50/50 runs me around $60 where the 100% is $90.
So $10/gallon of pre mix vs $8.25 if I added distilled water (at $1.50/gal). I use maybe 3-4 cases a year, so not really a big deal.
PCustoms
VT
How much to fix the leak?
