Different Hammers
cookiemonster
Could someone please explain the difference in striking hammers and what their intended use is for?
Brass hammer?
Copper hammer?
Dead blow?
Plastic and Rubber end hammers?
rlitman
Long Island
Aside from dead blow hammers which generally have soft plastic faces, but do come in all sorts of varieties, everything you listed has to do with the striking surface.
Generally, a harder striking surface will strike a harder blow, but you often want to choose a striking surface that does not harm what you are hitting. Choose too soft a striking surface, and you damage the hammer, or don't get a hard enough hit.
So, hammer striking surfaces are made in a wide variety of materials, to suit hitting a wide variety of things.
d.mcfarland
Western PA
Brass is non-sparking I believe, so when working around flamable materials many tradesman probably use them.
lzenglish
California
Brass hammer?
Copper hammer?
Dead blow?
I call them "Persuader Hammers". Used to assemble, or disassemble a part, so as not to damage, or mar its surface. Example would be tapping an armature shaft into its bearings, etc. Also used in leather working, and other crafts. The Dead Blow, is in a class by itself, in that it does the heavier Persuading work, like seating large bearings, as an example. At least this is how I use them, so IMO.
Wayne
basspro
In the sticks, WI
Your brass hammers are for striking, or persuading as lzenglish put it, it will still damage mild steel though if struck hard enough, it is also non spark. The deadblow just means the hammer has some sort of material in a hollow chamber in the head of the hammer, such as shot. The deadblow could be a ball peen, mallet, ect. Your ball peen hammers do almost all striking with a punch or chisel as the face is designed to not chip out when striking hard objects, it should be the most widely used hammer. Tne soft face plastic/rubber hammers are just that, designed for striking objects without damage.
neophyte
Pennsylvannia
Dead blow hammers don't recoil, i.e., bounce back, at least significantly when you strike something. In confined areas this helps prevent damage that can be caused by a hammer recoiling backward off the item you were striking, and impacting something that would be difficult or extremely expensive to replace or repair. Dead blow hammers also prevent the recoil that can cause repetitive stress injuries to a persons wrist or arm. I also heard of an incident were a sledge hammer that was being used to break something down recoiled backward into the users head, nocking them unconscious. For safety reasons a dead blow sledge hammer could have prevented this or at least mitigated the injuries. Brass, Bronze, Copper, as well as Lead and Aluminum hammers/mallets are sometimes classed as non-sparking for use in flammable or explosive atmospheres. They are also used to prevent marring on some materials. Another purpose is they have different densities and recoils so they are useful for precision adjusting of parts or machine setups. The denser materials, Brass, Bronze, Copper, and Lead, require gentler taps to adjust a setup as a lighter material would and therefore offer more control than a lighter hammer would. A number of these materials also have less recoil than steel. Plastic and Rubber hammers/mallets are used for Similar purposes as the softer metal hammers but using a material that's sometimes even softer. Plastic faces are sometimes used on heavier hammers to make a denser hammer that is both either non marring or has less recoil.
