diggin' holes...
OIIIIIIIO
Wisconsin
So, I rented an auger to dig some 12" wide holes 4' deep...a fairly big auger...hydraulic...tow behind my truck...still light enough to pull around by hand though...only able to get down to 3' before hitting clay and a rock or two in just the wrong spot...really need to get to 4' for the frost line...
would a more powerful auger do the trick...an attachment on a skidsteer...get me down to 4'? or should I just go back to a long steel spade and a post hole digger?
7 holes to finish..
fury9
Mchenry, IlLaHnoYs
probably, but you should just dig out the rocks by hand and dumping water in the hole works for loosening up the clay. And you only need to go down 42". I have actually beat down a posthole digger with a sledge. Just gotta remind yourself every quarter inch gets you closer.
Stuart in MN
Minneapolis
Without knowing where in Wisconsin he's located, 42" may not be deep enough.
If there are rocks in the way, it won't matter what auger is used, you'll have to drill in a different spot or dig the rock out.
O
OIIIIIIIO
Wisconsin
I'm in south central Wisconsin...near Madison...guys who dug the foundation went down 4+'...
These are footings for an iron fence...
BD1
north side
Boy, that's gotta be a heck of a fence. I'm at the Illinois / Wisconsin boarder.
I made four holes 12'' diameter and only was able to get down 36'' to 40'' too. Holes were filled with concrete just above grade. I got a grain hopper bin on it. Weighs about 9,000 pounds filled and has not moved or settled at all.
More info on fence may help. Is the entire hole going to be filled in concrete or just a poured footing.
jhelrey
MN
Just use a post hole digger and dig the rock out manually
O
OIIIIIIIO
Wisconsin
no inspection...just want it done right...it's not a lot of rock...just one or two in just the wrong spot...I went out and bought a big old steel bar and will dig it out and get the rest of the way by hand...
does this link work for a picture?
http://www.facebook.com/photo.php?f...20561579.70196.100001105295603&type=3&theater
on a side note...i marked this particular picture as "public"...would anyone tell me if they can see any other pictures on my fb? i try to keep it limited to just friends and would like to know from someone who is not my "friend" if other info is visible...thanks!
Costa Mesa, CA
I can see it just fine. Here it is for anyone that isn't able to:
Donald Cook
monee Ill
I'm not sure, is it me or is 12" kinda big for a fence post? I put up 400' of chain link at 6" 25 years ago and it hasn't moved.
O
OIIIIIIIO
Wisconsin
it is big...but it gives me some fudge factor...which I tend to need more than my fair share...
badbascom
I recently dug holes with mini skid steer (walk behind kind), despite there size it was heavy and you have to use down pressure (ie front wheels in the air) to get thru the nasty stuff, takes awhile but it will do it. I wouldnt break my back doing it manually. If you do it manually I would think a sharp shooter and a shop vac would be easier than a post hole digger at that depth.
Daniel Dudley
I have rented skid steers with the auger for about 300.00. They will dig a lot of holes for the money.
madstat
Southeast Michigan
Extra time spent on measuring sure beats several additional hours of backbreaking digging...the difference between 6" and 12" is huge.
x2 .... you would be removing 75% less volume going to a 6" auger. Careful layout and attention to detail is what's needed here.
djkeev
North Western New Jersey
A four foot deep hole a foot in diameter to hold up a four foot high fence!?!?!?!?
You realize that you could erect a small building on those footings?
Relax, it's just a fence.
Dave
O
OIIIIIIIO
Wisconsin
you guys are probably right...just want to get below the frost line to prevent heaving and twisting it apart...but there are plenty out there that don't have those deep footings that have survived...
Todd.Brock
Cincinnati
I think your killin your self unnecessarily. I live in Ohio. Our frost one is about 30 inches. I dug 6 maybe 8 in holes. And dumped a bag of quickcrete in each hole. Most people I talked to only cemented corners and gate posts. Sve your self the trouble and call it good!
Todd.Brock
Cincinnati
I think your killin your self unnecessarily. I live in Ohio. Our frost line is about 30 inches. I dug 6 maybe 8 in holes. I used a stihl one man auger from the rental place It was a weedwcker motor on a drill bit I dumped a bag of quickcrete in each hole. Most people I talked to only cemented corners and gate posts. Sve your self the trouble and call it good!
