diluting Ghostshield 4500
misterfixit
Kaufman Texas
Just making sure here before I start.....
Using GS 4500 densifier on new (3 month old) shop floor, was power troweled very smooth, 1200 sqft. Still need to dilute 4 to 1, making total of 5 gallons?
Shea
California
If you are going to be applying GhostShield 8505 or 8510, then the 4 to 1 dilution for a power troweled floor is correct. Makes sure that it does not puddle.
Shea
California
It would be 3 to 1 then. Again, just make sure it dust not puddle. You don't anything more than a wet sheen when applying it.
Garage Flooring
Grand Junction, CO
This is 100% correct. DO NOT OVER APPLY
Only what soaks in right away. Do not allow it to puddle
686sx
PA
When is it appropriate to use 2 to 1? That is what the sheet from Ghostshield called for. Is there a benefit or downside to using to rich a mix?
Garage Flooring
Grand Junction, CO
If you are using it with 8505 or 8510 just DON'T.
If you are using it over power troweled concrete Don't
If you are using it over porous concrete as a stand alone densifier, ok but be careful
686sx
PA
Did mine today at 4 to 1. 2400 sq ft power troweled Used 1.5 gallons(7.5 total) of 4500.
I bought more than i needed....Now how much 8510 will i need?
