KPack
I'm looking at using Lithonia CPHB LEDs in my shop. Probably 12K or 14K lumens. Shop is split into two equal areas of 36'x'36x14'. I plan to use either 6 or 9 (2 or 3 rows of three) in each room. Lithonia CPHB
These lights come with purple and gray wires for dimming. My questions is do I need to use these wires for dimming? Or is there a switch option that will control the voltage to the lights without having to run additional wires?
Second question, if I do have to run the wires, how are most guys doing this? I'll be using MC in the attic space, then dropping down to connect into the lights. Do the purple and gray wires need to be run in conduit or do most people just staple it along the framing? I'd rather not run conduit up there if I can avoid it.
I'm new to all this. Just want to make sure I'm doing it right.
