Dimplex Garage Heater
Chris5303
IN
I am a home owner that has a lot of previous success with some pretty heavy DIY projects including running a 100 amp box in the garage and adding 7 outlets on 3 breakers, etc.
That said I just purchased a Dimplex euh12b84ct and have not been able to get it running.
I've run it about 7 feet from the box from a 60amp 2 pole breaker with 2 6 gauge wires running from the hot to heater and and 8 gauge ground.
The fan turns on when the thermostat is below the room temp but that is all I can get it to do.
Power is getting to Contactor but I am not sure where to go from there on the Trouble Shooting. I have a Multimeter but I'm a bit of a novice with it.
I bought a Thermostat to replace the one on it but have not hooked up yet. My first time with a 240v Themostat.
Thanks for any help you can offer.
C
Chris5303
IN
I was under the impression there was away to run it off of the 240 connection from the single phase 100 amp box.
Is that something I can do?
C
Chris5303
IN
The wiring diagram shows 480VAC - is that what you have?
Thanks for the Reply!
So from what I'm reading and what I think you are getting at is this can be single phase but essentially still needs to be run off of 480VAC which is essentially just a modified 3 phase.
A normal single phase 100 amp box wont work?
Bert_
NW Iowa
You need 480v for that heater, single phase or 3 phase but it needs 480v. You only have 240v available.
Also photo looks like you ran individual wires but no conduit. That's a pretty big issue.
C
Chris5303
IN
Thanks. Doesn’t seem like 480v makes sense for me to get. I did run flex conduit just needed to be tightened, never made it there because I tested it and it didn’t run.
Bert_
NW Iowa
Sell this heater and get one that runs on 240v
jlv03
SE IA
Hard to see from the diagram, but it appears there is a 480-240VAC transformer in use for the controls. At first I thought it was 24VAC, which had me confused as it would seem a bit strange to have a 24VAC blower fan. 240VAC makes a bit more sense.
You could dump/bypass the transformer and get something to work. However the heat output would be MUCH lower ran at 240VAC vs. 480VAC.
