Direct burial #2 aluminum and j box
manminder
Vancouver BC
Help with question please,
I have dug a trench and laid down the direct burial #2 aluminum, Do i just peel back the rubber and aluminum shell in a j box and bring the wire in the garage?
The aluminum shell is very sharp, i am afraid it will nick the inside wires.
Is this the proper way to do it?
PRH44
Indiana
Sharp AL. shell on direct buried cable HMM... What type of direct buried cable did you use?
PRH44
Indiana
You have PVC coated cable . There is a connector that is rated for this cable. The connector will connect to the enclosure (box or panel). The pvc jacket and the aluminum armor terminates in the connector. The conductors then route in the enclosure
PRH44
Indiana
Is this your cable?
PRH44
Indiana
It appears you have a type AC (armored cable), the photo is a type MC (metal Clad). The MC has a full size grounding conductor. The type AC will have a smaller bond wire that works in conjunction with the Armor to form a ground path. Can you tell me how many full size conductors you have in the cable?
PRH44
Indiana
Are installing a single phase feed?
How are the individual conductors identified?
pattenp
Virginia - USA
That cable can be run all the way to the panel box with the metal jacket being terminated in a clamp with a red bushing like these. It doesn't need to be in conduit.
LoadImage.aspx
images
