Direct burial cable in crawl space
Nashcat
I’m replacing the feeder that goes to my garage, from my main panel in the house. My question is, how do you run direct burial cable through a crawl space? Is conduit required? The wire path, through the crawl space, saves me about 20 ft of cable, and 75 extra ft of trenching.
Thanks
mike93lx
Richmond, VA
Conduit everywhere above grade.
That said, what is the rating on the jacket? URD is generally not permitted indoors, which is one reason Mobile Home Feeder is often preferred
Also, 4 wire feeder, correct?
N
Nashcat
This is 2-2-2-4, underground mobile home feeder cable, from Lowe’s. I guess PVC conduit is in my future.
u2slow
BC
If OP is in Canada, there are a couple of direct-burial approved armoured cable types that can be used above grade.
mike93lx
Richmond, VA
Fair, although his profile does say us.
Can you link the cable types you are referring to? Curious to take a look
LOW1
ontario
Can you run the direct burial wire to a junction box where it enters the crawl space, then run proper above ground wire to a second box where it exits the crawl space and then return to using direct burial wire after that?
