Disappeared Into Thin Air!!
Merkava_4
Clovis, CA.
I was disassembling my F936 tonight and dropped the little ball on the floor. After crawling around the living room on my hands and knees with a Streamlight Stinger and a telescoping magnet for 3 hours, I've finally concluded an unnatural phenomenon has occurred: the disappearance of a little steel ball. :(
dps
Put a fresh bag in your vacuum cleaner and vacuum the floor. Check bag.
TheToolMan
N.J.
I will tell you a little secret that a detective taught me when i was working at the finger print lab building surviallence vehicles. When they are at a crime scene looking for small objects on the floor they get their flashlight out and lay it on the ground paralel to the floor shining the light across it. Get down on the ground behind the flash light and look down it like the barrel of a gun. This will magnify everything on the floor casting long shadow as well. Let me know if this works out for you
speed bump
Butte Montana
Its often where you least expect to find it. I lost the little Bal out of my Napa NB41, then I found it, then I was resassembling it and dropped the ball in the hole in my chair and lost it again. Also i'm not sure about SO ratchets but that NB-41 doesn't work quite as well with a bigger ball (The hardware store only had bigger sizes and I didn't want to try and chase down the correct size.)
wrenchr
Was it broke??
If it was a hard wood floor then it is gone, they bounce like crazy.
Rickster
SE PA
Sometimes it'll hit your shoe and bounce off further than you think, try widening your search area. Also my Dad has a huge-*** ring magnet on a 3 ft handle he got from Harbor Freight for finding stuff he dropped on the floor and he says it works great. Looks like this one: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42288
Chris Adams
Best of luck. All are good sugestions (Well, almost all...).
We once lost a sight spring from a SuperBlackhawk in a small room. We tried all those tricks, even taking everything from the room out, carefully, one item at a time. NEVER found it.
So anytime anything disapears around here we call it a 'Ruger spring'.
I think you have one.
dxdexter
I have a feeling that if you find the ball, it will be in the last place you look.:)
sputnikv8
try this....
cover your hands and knees with that red lube stuff you rave about. Crawl around for a few minutes and then see if it stuck.
Oh, and take good pictures.
russlaferrera
Central Virginia
pl_silverado
West Bradford, PA
Thats why i always have one of these under my ratchets when disassembling them. Theres a reason your snappy guy does the same.
Magnetic parts try woulda saved your ball :D
Stuey
28m above sea level
get [your] flashlight out and lay it on the ground paralel to the floor
I use this technique sometimes as well - nothing works better for locating small pieces of glass, crystalline materials, or metals. Plus, this method helps one see how clean or dirty their kitchen floor really is.
charlie_nj
That technique is called sidelighting, and as a previous poster said it's main use in law enforcement is at crime scenes looking for fingerpriints.
Now you have something in common with John Kruk and Tom Greene.
Stuey
28m above sea level
Well, technically it is used in a lot of fields, not just (or primarily) crime scene investigation.
In optical and electron microscopy, "dark field" illumination is used to highlight topography and other such features that are not visible when illuminated head-on.
<>Severed<>
Idaho
Sounds like when my father-in-law drops a small diamond at work. my wife has a talent for finding them, (aparently she is drawn to diamonds). Good luck with the search, either finding the origanal or a replacement.
kartracer55
The best part about it is that its still there. I always get close to giving up on small parts, but then I always remember that since there are no small drains in the floor, its still around.
Keep looking man.
Merkava_4
Clovis, CA.
Thanks guys for all the tips, but it looks like I'll be ordering a rebuild kit. Even if I had a kit ready to go right next to me, losing that little ball would still bug the hell out of me. :eek:
swgray
maryland
Check your shoes, sometimes small things get stuck in the laces. Even check your pockets, especially if you were sitting down.
