I am going to be needing a single phase 240 v disconnect switch. This will only be used in the event of an emergency. I have a 240v circuit in my attached garage. 50 amp breaker is in panel on side of house. This switch will be installed in case I need to shut down the circuit and won’t need to go around the house. Satisfies code as well. Down line of the switch will be a rotary phase converter with 7.5 amp motor generating the third phase. This will power a milling machine that will have a 3hp 3 phase motor that is rated for 9.6 amps and about 20 amps on start up.
The readily available single phase disconnects are 30 or 60 amps. What should I use as a disconnect on this circuit?
Here are a few affordable choices for Home Depot:
https://www.homedepot.com/p/Eaton-6...connect-Molded-Case-Switch-DPB222RP/100193214
https://www.homedepot.com/p/Square-...kW-Non-Fuse-AC-Disconnect-QO200TRNM/202844936
