JDewey
I am working to finish out the wiring inside my shop. I would like to put what is referred to as "Safety Switches" (but I call "cut-off boxes") at several points in the shop. These will be located at each location I have "heavy" power equipment. Specifically, where I will have a welder plug in or a mill plug-in, etc. These boxes will have a lever shut-off/turn-on switch that will shut down or turn on the equipment that is plugged in to the switch.
Because the welders, etc. are rated at 50A (240V single phase), I am looking at a 60A, single phase, non-fusible NEMA 1 style box, suitable for 15 hp and I will wire them to the circuit box at either 30A or 50A, as applicable for the specific equipment limits. The leading contender (based upon price) is the Siemens GNF322 60A, 240V, single phase safety switch. Square D looks good also, but is much more expensive.
The plan is to wire to the "Safety Switch" from my Circuit Breaker-based distribution box and use the lever on the "Safety Switch" to turn on or cut off the equipment.
Any thoughts?
Any thoughts?
