MushCreek
I'm going to attempt to repair my leaking Mitsubishi mini-split. The leak is in the interior heat exchanger coil. I can get a new one for less than $200, and I'll have my A/C guy evacuate and re-charge it when I'm done. I have a service manual, but I'm not sure how to shut off the refrigerant lines. There's a gas valve and a liquid valve. I assume I shut them off first. Then I should be able to disconnect the lines at the coil, although some freon will leak out. The manual calls for 'pumping it down' first, but I don't have the equipment or know-how, and don't want to pay for the A/C guy to come out. Since it's been leaking, and hasn't been run in a couple weeks, I'm assuming that there won't be that much pressure or freon left in the lines.
Am I looking at this right? Any pointers? I guess the small amount of freon won't hurt anything, as it's been leaking anyhow.
