Hello to all:
I have a chance to pick up a 9,000 LB two post lift for a good price,but the dismantling of it looks tricky. The sheetrock ceiling is about 8 1/2' tall and the top column of the lift is bolted to it. In other words I can't lift the lift vertical to get it off the anchors. I believe the lift was there first then the ceiling was put in as a remodeling job
I'm going to assume that there are ceiling joists that the top column is bolted to.
It might be possible to hammer down the floor anchors paste the base plate but I'm not sure how to lean the columns down.
I will probably have to cut out some sheetrock and maybe twist the columns into a joist bay ??
Thanks Greg
Thanks Greg
