Dissimilar Metals in Air Setup
MNiceGuy
I'm planning to install copper air line in my garage this weekend and considering the cost of some of these materials, I want to make sure I get it right the first time. This is my first mixed metal plumbing so I want to make sure I'm paying attention to which metals have direct contact with each other.
Here's my sketch of what I want to do. The copper is there to take the full tank pressure (175psi) to the regulator where it will be reduced for connection to a Maxline setup. I chose copper for its cooling benefit as well as having a little extra piece of mind for the pressure involved (3/4" Maxline is rated to 200psi @ ~70*F). This also allows me to place the regulator at a more accessible location.
Based on my drawing, are there any areas where I should do something differently?
fitter30
Peace Valley,mo
Use unions on both sides of regulator for removal. No air or auto water drains before reg or shut off valve from tank?
MNiceGuy
The regulator is a filter/regulator combination. There is a ball valve on the tank but then nothing between it and the regulator.
GrayFlattop
Chicago
No issues whatsoever. Brass is ~70% Copper, so they are basically the same.
Steel, about the only issue there is that will rust given enough time, or a lot of water in the air. You should be ok for the first 20-30 years though. Or just by brass ******* if you are that concerned or if your air is wet
MNiceGuy
You will not have issues with dissimilar metals in air service. Relax.
Is the rule generally when there is water present (electrolyte)? I have seen water cooling setups where someone combined an aluminum radiator with a copper heat sink and it didn't end well.
ycgoat
S.E. Va
Yeh, I use pipe dope on plumbing, anti-seize on bolts, and ant-oxidant on electrical, but corrosion seemed best dealt with anti-oxidant. It may be any of them will work
claymont
CLAYMONT, DE
Look up dielectric union.
