distance between knockouts
PoorOwner
CA
I looked at the bottom of the panel and I just see all concentric 1/2 3/4" combination.
I need to drill out one of the 3/4 to 1", just wondered if it is going to be close to their neighbors? I guess the hole is only going to be enlarged to 1-1/8" to 1-3/8"
P
PoorOwner
CA
The neighbor KOs are going to remain un-used, that is how I picked the location.
Slowgsr
Southern ontario
Step bits work great for enlarging. Unless your new hole covered half of a prep punched k.o. Then I use my hydraulic k.o. Punches!
Once I was in a pinch and cut a hole with tin snips and used some reducing washers to clean up the hack
alfredeneuman
Fullerton, CA
I've used 3" flat octagon cover plates screwed to panel's KOs of larger (1-1/2" to 2") instead of re-washers lots of times. The cover plate is much stiffer than the washers, and allows for better grounding when using conduit
Bert_
NW Iowa
Same here, I used 4 square blanks though. Did it the first time out of necessity since I didn't have the right reducing washers but realized how much better the cover worked.
Pretty much became a habit with bigger motors, 4" cover works great when they give you a 3" hole but I only want 1 1/2" conduit. I just punch a hole and screw it to the box with ground screws since they are thread forming.
