Hi, my house was added on to by the previous owner and the meter had been moved. When they did this they put a disconect on the inside wall where the meter is located on the outside wall. This disconect then feeds my main panel which covers the house and the garage is fed with a 20 amp breaker that connects to a 60 amp four spot fuse panel. I know your full of envy....
. My friend says I should just ditch the disconect for a 100 amp panel with a main shutoff and then use that panel with a 100 amp breaker to feed the house main panel which would now be a sub panel and use a 60 amp breaker to feed another sub panel in the garage with 2-2-2-4 aluminum service wire. Sounds good to me.....Any thoughts or concerns that we over looked.............Thanks.....Mike
