Stinger
I just bought a new home with a 45x60x13 pole barn/shop in Kansas City with 6x6's and rafters on 8' centers. The only insulation currently is on the roof. It's just white bubble material (1/4" thick) with no reflective facing and the seams are overlapped about 2" but not taped. This is installed between the purlins and the metal on the roof.
Currently I'm leaning towards some sort of faced fiberglass from Bay Insulation as I think it will be one of the easier DIY methods that's not overly expensive.
I'll be moving in late Sept/Early Oct so I'm trying to get all the details figured out ahead of time. I'll be heating and cooling the shop (undetermined what type of heat/ac unit, that's another thread). I can't figure out the best way to heat/cool it until I know insulation R-value and cubic feet. I don't necessarily need to maintain 68 deg year-round but I'd like to be able to maintain heat it to 60 in the winter and cool to 75 in the summer. Typically in this area there are a few weeks each winter with highs in the mid teens (lows near zero) and a few weeks each summer with highs in the 95-100 deg range.
Things I'm trying to figure out and would like feedback or info I may not have considered:
1) Is there a massive benefit to taping up all of the seams on the bubble insulation currently installed?
2) Should I add additional insulation to the roof, or should I put in a ceiling (or strapping) and install insulation on the bottom of the rafters? The main concern here is putting it on the bottom of the rafters will cut down how much space I have to heat/cool. I'm not sure how large the benefit will be though?
3) If I do a ceiling, what material to use (straps only, steel, plastic, some other option I'm not aware of). Keep in mind the rafters are 8' apart so most materials will require me to add wood between the rafters to support the ceiling (more work & $$$).
4) Would blow-in insulation be a better option for the ceiling?
5)Wall coverings; I'd prefer to cover the faced insulation with something to protect it from being damaged and also to improve the looks. I've looked at metal (all the way to the rafters or maybe just 8' up and then leave the insulation visible above that, particularly if I insulate the roof instead of adding a ceiling).
6)Is there anything I need to consider as far as venting the roof, preventing condensation, humidity mitigation, etc. that needs to be done before I finish the interior?
Please let me know any insight you may have, thanks for your time.
