BrandoJames
I retired two years ago (DoD computer nerd for 30 years). I’ve spent a lot of my free time on DIY automotive repair/maintenance for my extended family. I recently took on some DIY plumbing tasks and learned a few painful lessons. After stripping a faucet and cracking a toilet tank, the main takeaway: you can’t wrench on plumbing fixtures the way you wrench on automotive fixtures.
A YouTube plumber put it this way: toilets, bathtubs and sinks don’t speed down the highway at 70 mph. They’re stationary, so there’s no need to arm-strong fasteners like you would with automotive work. For those of you who are just starting out with DIY plumbing jobs, a few suggestions:
1. Water cut-off: My toilets have cut-off valves, but most of my plumbing fixtures do not (old house). Go to your breaker box, find the breaker that cuts off your water (I have an electric pump/well). Then turn on faucets to drain the water going into your house before doing anything.
2. If you're going to use a ratchet, use a 1/4” ratchet. Don’t arm-strong anything.
3. Say hello to SAE sizes. If most of your tools are metric, then you’ll need to buy some SAE tools.
4. Power tools = No. Hand tools only unless you’re a pro or experienced DIYer.
I hope that helps the newbies out there. Good luck.
